Re: 2N fenders
Posted by Tim Daley(MI) on September 03, 2020 at 06:41:47 [URL] [DELETE] :
In Reply to: Re: 2N fenders posted by HCooke on September 02, 2020 at 16:53:20:
HiYa Harold-
LH dash, early 9N as shown, has pushbutton starter at top upper, lower LH under AMMETER has the Ignition "ON" lamp and a hole for a light switch. RH dash, Oil Gauge; Choke lever & knob; Ignition Key Switch. Lower Steering Box has a Left & Right cast boss with tapped holes that the battery hold down bolts secure to from the battery clamp behind dash. Here is a photo of Barry's dash. Holes #2 and #4 require ID’g. I suspect #2 is someone’s addition for a key switch, it was not as original. What is the cast boss & hole (#4) on the RH bottom steering box for shown about 6:00 O'Clock?
BARRY'S 9N/2N DASH:
Item #1 is Red Ignition Lamp, light switch to the right. #3 & #5 are the tapped bosses on steering box for the battery hold-down bolts from behind.
EARLY 9N BATTERY HOLD DOWN BRACKET AND BOLTS:
