Re: 8N pump base
Posted by JMOR on September 05, 2020 at 13:56:12 [URL] [DELETE] :
In Reply to: 8N pump base posted by Dave on September 05, 2020 at 12:08:39:
Can't say, yet. Most likely from freezing with water in the sump and if so, what you see may not be only crack. Take apart, thoroughly clean and inspect. Also, if it cracked into a valve bushing bore, that will also reduce the chance of successful repair.
