Re: Possible valve noise
Posted by Tlawing on September 07, 2020 at 16:23:51 [URL] [DELETE] :
In Reply to: Re: Possible valve noise posted by Bruce(OR) on September 07, 2020 at 14:53:20:
I didnít think it was the starter when I took it out to check. Stater was fine. The noise I believe is coming from the 4th cyl valve area. I have read the adj procedure in the manual. I donít have the tool. I believe I can use a punch through the hole to hold it. It also shows a 7/16 wrench that has been ground off at the tips and cut to 5 inches. I have ordered a thin wrench that should be here in a few days. I will give it a try.
As far as hearing I have trouble hearing anything. I say I canít hear you all day.
Thanks again for your help.
