Newbie needs help with valve adjustment
Posted by Tlawing on September 13, 2020 at 20:28:14 [URL] [DELETE] :
Would someone explain the procedure for adjusting valve tappets (These are adjustable). What I need is for someone to explain how to start with number 1 TDC. How do I know itís at TDC. Once number 1 intake and exhaust is checked or adjusted if needed then how do I find 2 TDC etc.
I assume the check and adjustment would be at TDC. Correct me if Iím wrong.
Thank you for any help.
