Re: 2n oil filter assembly
Posted by Francois on September 19, 2020 at 16:00:15 [URL] [DELETE] :
In Reply to: Re: 2n oil filter assembly posted by Tim Daley(MI) on September 19, 2020 at 07:12:18:
Thanks, Tim. Great info and the diagram is really helpful. So I guess the previous owner of my 9n added a spring instead of part 18677. Can you explain the oil flow then through the filter? I figure the oil comes through the bottom of the canister through the part 18677 then moves from within the filter outwards and exits through the side exit line, however since the filter is not mating with the canister lid, this must not be correct?
