Re: 9N main bearing studs
Posted by JimN on September 29, 2020 at 19:28:18 [URL] [DELETE] :
In Reply to: Re: 9N main bearing studs posted by TheOldHokie on September 28, 2020 at 19:00:14:
The reason I would like to use the correct studs is they have a correct snug fit at the middle “shoulder” to properly center the bearing cap around the crankshaft. Bolts or cap screws seem to have too much play and would allow the bearing cap to be off center.
I also am getting the block and caps line-bored and need the caps centered perfectly during that process.
