Re: 9N main bearing studs
Posted by TheOldHokie on September 29, 2020 at 22:26:11 [URL] [DELETE] :
In Reply to: Re: 9N main bearing studs posted by JimN on September 29, 2020 at 19:28:18:
I dont think the studs are anything special and I think you are worrying about something that does not matter. Have you asked your machinist about this? The bore does not have to be centered between the studs. It just needs to be round and straight. It can and will be high, low, left, right, and out of square regardless of what studs you use. This is due to setup tolerances in the process. That is true with the OEM bore as well and why caps dont interchange.
TOH
