In Reply to: Re: Hydraulic pump rebuild kits posted by Tim Daley(MI) on October 08, 2020 at 04:23:31:
Tim,
Thank you for your reply it is exactly what I was looking for !
Also thanks for your hydraulic lift repair guide as well, very well written.
I only want the kit on hand when I do drop the pump to clean it, the center plug is stuck bad.
So I had to go in through the right inspection cover and suck out remaining gear lube (no water) then scoop out sludge by hand, but can't thoroughly clean it so its coming down soon.
Once on the bench I'll be able to free up the plug.
Thanks again, Mark
