Re: the dreaded axle leak
Posted by John in Mich on October 21, 2020 at 18:23:14 [URL] [DELETE] :
In Reply to: the dreaded axle leak posted by lonestarjeff on October 21, 2020 at 17:36:52:
Definitly leaking. Until you can fix it, degrease that mess and lower the amount of Hydraulic fluid in the diffy. Pull the bottom bolt of the right side inspection cover The cover contains hydraulic dip stick. This should minmize the leak until you can buy the parts and fix it properly.
