Re: 8N Hydraulic Lift
Posted by Bruce(VA) on October 28, 2020 at 18:34:15 [URL] [DELETE] :
In Reply to: Re: 8N Hydraulic Lift posted by Del Huebner on October 28, 2020 at 16:46:14:
The jig provides a constant reference point for measuring the adjustments. The I&T manual has the measurements, but those measurements to not consider wear. If you set point A 1 inch from point B, you have no fixed reference point for point A or B w/o a jig . Even though you can easily adjust A 1 inch from B, wear in both A and B can alter the operation of the lift.
If I tell you to set both chairs 1 foot apart in the exact center of the room, you need to know how far apart the walls are.
https://www.just8ns.com/LG500-Years1939-52-Lift-Jig_p_2850.html
