Re: electrical
Posted by Tim Daley(MI) on November 08, 2020 at 04:57:26 [URL] [DELETE] :
In Reply to: Re: electrical posted by steve on November 07, 2020 at 10:30:47:
"...so it has to be a component..." -No, it most likely is in the wiring so don't start yanking off components and replacing with new ones. True root cause problem solving is always the method to use. Don't guess. Start by removing and getting the battery tested under load at a shop. Leave battery off or disconnect. Remove lights and switch. Go thru the entire wiring system and verify if right or wrong and take no shortcuts. "...well, I thought I'd try..." is a guess so avoid that way of thinking.
