801 rear main seal
Posted by Jeff in Northern Michigan on November 11, 2020 at 21:05:21 [URL] [DELETE] :
Rebuilding a 172 engine for an 801 tractor and have a question on how to install the seals along the rear main bearing block. The Ford Manual says to soak the seals in oil then immediately insert them in the bearing block. The new seals that came with my gasket set did not swell after soaking them in oil and inserting. How do these new seals work?
