Re: Key Fully Intact But Wont Go Into Ignition Switch
Posted by Tim Daley(MI) on November 14, 2020 at 13:04:26 [URL] [DELETE] :
In Reply to: Key Fully Intact But Wont Go Into Ignition Switch posted by Andres on November 14, 2020 at 12:18:31:
OK, so the key did not break off and was working a week ago. Did you try inserting it the opposite way? It will only insert one way. There is nothing you can "take off" or take apart -OEM switch is sealed and all 48-64 switches same and take the same key so can you try a different key? Also try a blast of WD-40 in key hole. If none of these work, just buy a new one. Here ya go'''
