In Reply to: FORD OEM CLEVIS BRACKET posted by Tim Daley(MI) on December 07, 2020 at 12:32:49:
Thanks for the reply Tim. This was the info I was looking for. I have the same clevis as pictured but the round section that the pin sits in has been cut off and replaced with a threaded block and bolt....works the same as original. Going to try and manufacture something close to original for now. Trying to restore mine as close as possible but not really much sense replacing the entire clevis assembly at this time. Should be able to get it close enough to original for now (may replace at a later date).
I assume the clevis pin slides in through the slots and then you just turn it a half turn so that it sits on the 1/4" pin?
