In Reply to: 2N thermostat posted by Daniel on December 17, 2020 at 12:35:59:
Dan-
Always use a Thermostat as emphasized. Get an upper hose from Just8Ns or Dennis Carpenter as it has the band to hold the Thermostat in place. Unit installed with pointed end towards radiator. If the water pump fails it is almost always because the bearing is shot and won't spin the pulley which then won't spin the fan belt which won't allow the generator to charge and thus may cause the belt to break or shred apart. The N's only had a temp sensor on the NAN versions -see MPC dash panel - and at one time they were going to add one on the 8N but decided against putting it into production, mainly because they were already working on a new model, the NAA, which would incorporate a temp gauge. Yet another reason to keep a belt tensioner on your generator and inspecting tension should be part of your routine checklist before starting up each time.
DASH w/ TEMP GAUGE MOUNTING PORT SHOWN AT 5 O’CLOCK FROM OIL GAUGE:
THE N-NEWS; “KEEPING IT COOL” –by BRUCE HAYNES
The “N-NEWS” is published quarterly and subscriptions can be found at www.n-news.com
or by mail at:
THE N-NEWS
9N-2N-8N-NAA NEWSLETTER
PO BOX 275
EAST CORINTH, VT 05040-0275
1 Year = $23.95
2 Year = $39.953 Year = $55.95
