In Reply to: Re: electron ignition posted by Bfordn24 on January 11, 2021 at 17:16:14:
I would look into why points get burnt up quickly as Bruce suggested before going over to the dark side (EI). I suspect it is in the wiring. Tell us how you have your 12V wired. By 'a stronger spark' is that because it is hard starting? Setting idle for weeks on and will drain a battery fast. Float chargers work wonders.
