Re: solar charger/maintainer update
Posted by steveVa on February 01, 2021 at 18:46:24 [URL] [DELETE] :
In Reply to: solar charger/maintainer update posted by cage on February 01, 2021 at 13:17:41:
Glad to hear that is working for you.
I thought of doing the same thing but could not decide if I needed to disconnect the batteries from the tractor.
So I took two 12 volt rv batteries I had hooked them to a 100 watt collector.
Took a 700 watt inverter and run my 6 volt charger that I had.
It is probably not real efficient, but it works great. I also run some 110 volt led lights with the inverter. And I run a 12 volt charger/maintainer for my truck.
