In Reply to: Rim Question posted by Tom(WI) on February 03, 2021 at 12:53:40:
OEM Ford N-Series rear hat rims were 9" x 28", supplied by Kelsey-Hayes. The tires were 10 x 28. The dimensions then were measured from the inside on both. The 10 x 28 tire is the SAME as an 11.2 x 28 now. 11.2 is the dimension when measured from the outside which is how they measure them now. Now you can get a 9", 10" and 11" 6-Loop aftermarket rim. A 12.4 tire will mount on a 10" or 11" rim. Cal Ed at Miller Tire and ask him -see LINK below.
FORD 9 x 28 HAT RIMS; 8N AND UP CENTER DISCS:
