In Reply to: drain plug gasket posted by pointer80 on February 03, 2021 at 17:20:46:
Did you remove all the old gasket material on the plug AND the pan surface? OWM plugs have a serrated surface for gripping. No sealant required. No torque wrench required. I always prep the new gasket with a coating of clean oil before applying it to the plug. Dab some oil on pan surface too.
