Re: 'Rinse' trans'
Posted by Dean on February 19, 2021 at 08:26:34 [URL] [DELETE] :
In Reply to: Re: 'Rinse' trans' posted by Tim Daley(MI) on February 18, 2021 at 19:08:39:
Do not use a strong solvent such as gasoline. Doing so will remove the Glyptal coating that prevents the insides from corrosion.
A small, electric pressure washer with warm water and soap would be ideal for the bell housing area. The use of common sense is assumed.
Dean
