In Reply to: Tractor will not start posted by Wings1 on March 08, 2021 at 17:58:54:
Explain your system, is it 6V/POS GRN or a 12V/NEG GRN switch out job? There is only one starter button - the neutral safety pushbutton by the shifter. The top of the starter motor has the SOLENOID, a relay. Burnt wires have a distinctive smell and should be a huge clue something is wrong and should shut down the system at once. Mucked up wiring would be a likely cause so get out your Essential Manuals, disconnect battery and lighting circuit, verify entire wiring with a VOM set to Continuity. Take no shortcuts.
FORD NAA, 600, & 800 ELECTRICAL w/TIMING:
FORD 600/800 ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
