Re: Broken Bolt Trans Cover - Extraction advice
Posted by John in Mich on March 31, 2021 at 15:32:48 [URL] [DELETE] :
In Reply to: Broken Bolt Trans Cover - Extraction advice posted by Kimberly on March 31, 2021 at 11:54:30:
Several options and I'm sure other folks will chime in.
1. Take the trans cover off. There may be enough bolt to grasp vicegrips then.
2. "Easyouts" Get a small set and the right size drill bit. Cheap Be careful of steel chips into the trans.
3. Weld a nut onto the broken bolt. Puts a head on the bolt and the heat may help loosen it.
