Re: Erratic idle
Posted by souNdguy on May 08, 2008 at 07:59:33 [URL] [DELETE] :
In Reply to: Erratic idle posted by JNewsom on May 08, 2008 at 00:38:50:
Grab the rod from the governor to the carb throttle butterfly.. and manually goose it.. does the governor fight you evenly.. no? then it needs attention. Might be as simple as setting the no preload/slack on the springs.. or as difficult as repairing grooves inthe housing and replacing flat balls..
soundguy
[ Follow Ups ] [ Post Followup ] [ N Board Forum ]
