Rear 8N Hub
Posted by Don on May 08, 2008 at 14:18:30 [URL] [DELETE] :
I replaced the seal on rear wheel and have the proper end axle play. However after installing hub and tightening big nut axle is very hard to turn. Loosen nut a little and hub turns o.k. Hub and axle splines do not look worn and hub does not seem to have any play when tightened on axle. However there is quite a bit of axle protuding from outside of hub. Any help would be appreciated.
[ Follow Ups ] [ Post Followup ] [ N Board Forum ]
