Re: 12 volt electrical Question?
Posted by steveVa on December 07, 2017 at 19:22:25 [URL] [DELETE] :
In Reply to: Re: 12 volt electrical Question? posted by Island Mike on December 07, 2017 at 19:01:38:
Very good point about staying with 12 volts and I do run several things including lights from 12 volts. I use the inverter to run 120 volt items, but turn it off when not in use to save the drain. The TV and computers are what I run from the 120 volt inverter. The 9 watt led light bulbs are also 120 volt. I wonder if they have 12 volt leds other then those car lamps with many bulbs?? I will have to look.
