Re: 601 workmaster 1957?"
Posted by TheOldHokie on July 31, 2021 at 22:33:27 [URL] [DELETE] :
In Reply to: Re: 601 workmaster 1957? posted by Earl on July 31, 2021 at 19:20:56:
Is the power at the coil switching ON/0FF when you crank the engine over?
Is the power sufficient to illuminate a 12v bulb?
If its not switching the points are not opening.
If it wont illuminate the bulb you have a problem in the primary circuit.
If all of that checks and the coil is good you should get spark.
TOH
