Re: ford jubilee timing
Posted by Bruce(OR) on August 15, 2021 at 20:32:07 [URL] [DELETE] :
In Reply to: ford jubilee timing posted by fordmancg on August 15, 2021 at 16:04:30:
Remove dist. insert the bottom gear in a vice,
easy.
Now twist the top. did it move?
What part? Did it stay moved or did it go back to original position?
You turned the rotor and it didn't return?
Ya' found your problem.
Then again,
i no nuttin' and others with vast more knowledge will be here shortly.
