Re: starter solenoid problem
Posted by Jack - Iowa on August 21, 2021 at 07:15:20 [URL] [DELETE] :
In Reply to: Re: starter solenoid problem posted by thad on August 20, 2021 at 09:21:17:
Believe I now understand your situation. You are saying you only hear the solenoid actuate when you ground the white wire. If this is correct and you don't happen to have the meter JMOR suggested, use a heavy cable and jumper across the two large terminals on the solenoid. If that turns the starter, your new solenoid is likely no good.
