Re: Rebuilding Front Mount Distributor 8N - Point Sets
Posted by Kimberly on August 29, 2021 at 21:17:33 [URL] [DELETE] :
In Reply to: Re: Rebuilding Front Mount Distributor 8N - Point Sets posted by JMOR on August 29, 2021 at 16:11:05:
This is with the breaker plate out of the distributor; no cam to hold the points open. The points appear to close but with a high power lens you can see the gap in the point and the fact the faces of the contact surfaces are not aligned. Ohmmeter shows the points are open. The old point set with the ohmmeter show zero ohms, closed, contact. The new points, ohmmeter shows OL. Two different sets of Blue Streak have the same; open contacts even when closed.
