Re: old ford tractor
Posted by carl on September 09, 2021 at 07:57:23 [URL] [DELETE] :
In Reply to: old ford tractor posted by ron on September 08, 2021 at 15:05:04:
Model year means little to nothing. The important factors are if it has a front mount or side mount distributor and if it is using the OEM 6V/POS GRN electrical system or has a 12V swictheroo been done. The <> Diamond symbols before and after the s/n would indicate a later 8N, NAA, or Hundred Series Model with the angle mount distributor. Why did you buy a new carb? Do you have a non-starting tractor?
Did you perform the fuel flow test first? The original carb can be rebuilt again and again. What is the old carb number? Ford used Marvel-Schebler. Why do think it is wrong? Don't guess and just start buying new parts. Troubleshoot. Get and use the correct manuals and documents as your guide.
