Re: 8N Hydraulic pump re-installation problem
Posted by carl on September 12, 2021 at 10:24:32 [URL] [DELETE] :
In Reply to: 8N Hydraulic pump re-installation problem posted by Charles Hudson on September 12, 2021 at 06:07:44:
The key is to have a buddy help guide the control valve lever into the pump base socket while you're setting the top cover on. Your front loader still utilized the system hydraulics so the PTO was running regardless if the STAY BARS were set and the lift not used.
