Re: Front wheel 8N compatibility with NAA
Posted by KCM on September 12, 2021 at 18:51:21 [URL] [DELETE] :
In Reply to: Front wheel 8N compatibility with NAA posted by Mark M on September 12, 2021 at 17:49:44:
Yes. The front center axle, wheels, hubs, and spindles from a NAA will fit an 8N. And yes, the rear rims, tires, center discs, axle, hub, and brakes are the same too. Three point arm components and fenders also fit. Hydraulic lift and motor are not. Some transmission parts will fit as well, including the shift cover. Compatibility of other parts are hit and miss.
The NAA is the same tractor as the Golden Jubilee, 1953 was a Jubilee, 1954 a NAA.
