Re: '50 8N
Posted by JMOR on November 30, 2021 at 09:53:15 [URL] [DELETE] :
In Reply to: '50 8N posted by Chy NY on November 30, 2021 at 08:12:37:
When lift reaches upper limit of lift, the piston/ram extends out of cylinder enough to contact a pin in the lift control arm, which is designed to kick the hydraulic valve into "neutral" or no lift position. If not doing so, you probably need to make some linkage adjustments or possibly have bent/worn/broken linkage, maybe causing piston to miss contact with pin.
Second picture is NAA tractor hyd, but the stop limit pin function is the same.
