Follow up 3 pt. lift
Posted by Chy NY on December 03, 2021 at 18:25:23 [URL] [DELETE] :
1950 8N No implement on it. Right side cover off, Everything looks OK with pto engaged. Drained most of the oil and things still look OK, however with the lever full up, the rod does not push the valve all the way in. I can manually push it in 1/4 inch further.
When moving the lever down about 3 inches from full up it no longer moves the valve and has no effect on the valve the rest of the way down. I will be installing a 'new' pump from Just 8Ns, but first will remove top cover to check out adjustment and cylinder and piston. Think I need a Zane thing to adjust rod. Any discussion appreciated, Thanks, Chy
