Re: Throw out bearing hub springs
Posted by mhb@ufe on December 04, 2021 at 19:38:01 [URL] [DELETE] :
In Reply to: Throw out bearing hub springs posted by Mike Maiman on December 04, 2021 at 17:00:41:
Do the springs pull the hub all the way back on the input shaft tube? If they do then you need to adjust the pedal height with the clutch pedal adjusting rod.
Mark
