Re: Piston to head clearance
Posted by Steve Dabrowski on December 09, 2021 at 15:35:54 [URL] [DELETE] :
In Reply to: Piston to head clearance posted by Mike Maiman on December 08, 2021 at 21:57:54:
Set the head in place without the head gasket and rotate the crankshaft, if it doesn't touch it is ok, if it does then grind away the inner surface of the head until it clears. Use Dykem on the combustion chamber to see where it hits.
I think this procedure gives about 0.050" clearance.
