Re: Identifying my ford
Posted by Tim Daley(MI) on December 29, 2021 at 17:32:02 [URL] [DELETE] :
In Reply to: Identifying my ford posted by Randy on December 26, 2021 at 17:56:03:
Randy-
Here is a taste of the wiring sketches from the MPCs for the 9N. In addition to the start pushbutton switch, there is a switch behind the dash. Don't confuse it with roundcan cutout for the GEN. They are two different animals. The start pushbutton can go bad, but I'd perform a thorough true root cause problem solving method first. Is it the OEM 6V/POS GRN setup? Yank out battery and take to a shop to be tested under load on their machine. While out, go thru the entire wiring system. If 6V, should be a 1-Wire/3-Brush GEN with the roundcan cutout. The GEN must have a belt tensioner or else it won't charge battery. Also there is a 1-Wire starter motor and NO solenoid; the Ballast Resistor; Front Mount Distributor; Ammeter, ignition switch, and if any lights, disconnect for now. N's never had lights from the factory -always optional dealer accessories and often were hooked up by the farmer and often wrong. 12V conversions are notorious for mucked up light wiring.
FORD 9N TRACTOR 1941 MASTER PARTS CATALOG:
FORD 9N TRACTOR ELECTRICAL SKETCH:
