Re: 1952 Ford 8N will not start!
Posted by steveVa on January 12, 2022 at 15:39:25 [URL] [DELETE] :
In Reply to: 1952 Ford 8N will not start! posted by Dead Eye Dave on January 12, 2022 at 05:51:14:
First guess. Flooded.
If gas was on and float valve leaked. Flooded. Loosen intake hose connection and see if gas runs out.
Second guess coil or connections to coil. Check all connections for voltage. If key left on over an hour. Coil can overheat. Check points first. Then swap a spare coil to it. An auto coil will do for a test.
