Re: Steering Wheel
Posted by Mike Maiman on May 02, 2022 at 17:02:44 [URL] [DELETE] :
In Reply to: Steering Wheel posted by Al on May 02, 2022 at 08:26:22:
Don't know anything about a screwed on steering wheel but before you twist and turn needlessly try this. Center drill the steering wheel nut so that the tit of a 2 jaw puller screw centers in the nut. Screw the nut back onto the steering shaft but leave it a few threads loose. Install the puller hooking the jaws under the hub and tighten the puller screw with some serious torque. Now heat the steering wheel hub and within a couple of minutes it should pop loose. You can braze the hole in the nut closed, sand and paint good as new.
