In Reply to: Re: donnahoo posted by JMOR on May 05, 2022 at 16:39:07:
JMOR, the issue has been resolved. The orig. float was set at exactly 1/4 inch from stem to stern. For this aftermarket carb. that is not sufficient. Every time I would go up a hill, it would just die. That was because the float bowl was nearly full and when at an angle, it would just float up, stop the flow of gas, then stall. So, I didn't want to mangle the float too much, so I just bent it in a downward position. So far, it is working fine. I'll even it out if it gives me problems. Thanks for the info. Frank
