Re: Ford 2000 plow model
Posted by Jim on July 08, 2022 at 01:39:43 [URL] [DELETE] :
In Reply to: Ford 2000 plow model posted by John on July 07, 2022 at 11:10:25:
The FORD 101 Series Plows were designed for the THOUSAND SERIES TRACTORS but work great on N's and Hundreds as well. The FORD 101 was much better designed unit than the previous DEARBORN/FORD ECONOMY Series Plows. 101's now had a trip function with shear bolts so moldboard damage was minimized if an obstruction was encountered. The new plows also had an adjustment lever from which the operator could control with from his seat. You don't need the coulters to work a plow but you do need the rolling lanside, also called the tailwheel, to plow with so watch for that. The good news too is that you can still get 14" and 16" moldboards for these. Any older ECONOMY Plow or even the older Moldboard (Prior) Model plows will work too, but I'd go for a 101 Plow. Here's a LINK to the A&O Manual from our MANUALS library.
FORD 101 SERIES PLOW:
