Re: Oil leak part?
Posted by Ed Gooding (VA) on July 11, 2022 at 18:18:21 [URL] [DELETE] :
In Reply to: Re: Oil leak part? posted by Travis Webb on July 11, 2022 at 13:44:17:
No. The drips indicate that you have a leaking seal(s). You won't soak your clutch if the cotter pin is there to rattle around and keep the hole open to weep. It comes down to how much is leaking - several drops after use are something you might tolerate. Just use your judgment on how much oil you are losing and what you are comfortable with to justify splitting her and replacing the seals.
