In Reply to: Will this damage anything? posted by Kimberly on July 06, 2022 at 10:17:24:
We used that same setup once years ago to pull an old drag disk. Fortunately no damage to the tractor. I have a ‘51 8n with the swinging drawbar kit on it and I prefer it over hooking underneath the differential housing. I saw a picture years ago on another forum of an 8n that the entire back end between the axle trumpets was busted out and you could see all of the differential. I believe the story was the owner hooked a chain underneath and got a running start and tried to snatch a stump out of the ground with disastrous results. You can get a swinging drawbar kit for around $125 less tax. I need to put one on my ‘49 and also update the PTO to 1 3/8.
