Re: 3 point hitch pin loose and leaking
Posted by Bruce(OR) on August 07, 2022 at 01:08:02 [URL] [DELETE] :
In Reply to: Re: 3 point hitch pin loose and leaking posted by Daniel Romans on August 05, 2022 at 15:41:01:
JB is a soft epoxy. A harder epoxy, a much harder epoxy would be Marine Tex. Designed to be used on boat hulls and dries hard as concrete. If you use Marine Tex or similar boar hull repair epoxy, Be aware that it will dry hard as a brick and be very difficult to sand off. Those pins are also subjected to the implement attached to them and will wobble around if not repaired correctly. Marine Tex might hold up just fine but no guarantees.
