Re: Ford 2N Ignition Coil Circuit
Posted by Phillip G. on August 09, 2022 at 15:30:41 [URL] [DELETE] :
In Reply to: Re: Ford 2N Ignition Coil Circuit posted by JMOR on August 09, 2022 at 15:15:37:
I just can't remember what the maximum & minimum ohms, and or amps should be at the coil that I figured out when I did the 12V conversion. I have an inline porcelain resistor in addition to the factory resistor behind the dash, so I must have wired that for a 6V coil at the time.
