Re: Ford 2N Ignition Coil Circuit
Posted by Tim Daley(MI) on August 11, 2022 at 17:01:11 [URL] [DELETE] :
In Reply to: Re: Ford 2N Ignition Coil Circuit posted by Phillip G. on August 11, 2022 at 16:24:32:
Phil, yes you did! Look two posts down... "...12V battery & coil. I'm running an alternator..." Again, you REMOVE the ROUNDCAN CUTOUT from the circuit altogether when doing a 12V switcheroo job on the 9N/@N tractor. Use PICTOGRAMS by JMOR for your roadmap. I advise you get a new coil, preferably a certified 12V coil. Have you got into the distributor thoroughly? Last time you rebuilt it? If base is busted, maybe 100% of your issues. Start there, time test mount and try it.
Tim
