Ignition switch
Posted by woodworker40 on August 18, 2022 at 07:29:51 [URL] [DELETE] :
I have a Golden Jubilee and I had a problem with the starter button, so I replaced it with one from Ct. tractor. When I hooked up the wire the starter engaged. So I decided to just replace it with a ignition key.
This is where I need help what wire goes on the ING. terminal, For the Batt. terminal do I have to run a wire directly to the battery?
Next the Starter terminal how do I hook this one up? Do I run a wire to the starter or to the solenoid?
The new Starter Button when checked with an ohmmeter there was continuity when checked from the terminal to the side of it. The old one did not check out that way.
