Re: Ignition switch
Posted by Ed Gooding (VA) on August 18, 2022 at 10:46:41 [URL] [DELETE] :
In Reply to: Re: Ignition switch posted by Tim Daley(MI) on August 18, 2022 at 10:37:22:
If you understood him perfectly, then why this response?
FACT: 99.98% of all non-starting issues are due to incorrect wiring regardless if 6V or 12V. If you don't understand the 6V system you are not going to fathom the 12V system. If it ain't running on 6V what makes you think it will on 12V? Blind Luck?
In case you forgot, you are not on YT right now. If you want to channel Dell, take this rude crap over there.
