Re: 841 Powermaster Electrical Help
Posted by jrobin1 on August 30, 2022 at 16:51:44 [URL] [DELETE] :
In Reply to: Re: 841 Powermaster Electrical Help posted by Bruce(VA) on August 30, 2022 at 15:46:26:
I am using the resistor because it says to use with external resistor. There is no internal resistor. I swapped out the old resistor with a new one I had on hand. Got the tractor started and while running it still has 12v at coil input side. So is that normal, or should I have 7-9 volts at the coil input side?
