Re: 1957 Ford 640
Posted by Terry in Mo (T-Mo) on September 05, 2022 at 13:13:37 [URL] [DELETE] :
In Reply to: Re: 1957 Ford 640 posted by Gaspump on September 05, 2022 at 11:44:37:
He says it will come with a post hole digger.
He said it ran good, but with the ignition switch issues, it won't start now. I will, first see if the engine is loose, and then see if it will crank....with it being out in the weather, things may have gotten wet.
And the model number and serial number is on the transmission housing behind the starter, not on the engine.
